I thought this would serve as a good reference for what works on what machines. If we use a single post we can keep it updated for the type of machine. I'll start.
Machine: Enco RF30 round column Mill/Drill
CNC: Paul's CNC kit
Software: LinuxCNC
Rapids: 21 IPM (software capped to keep the racking and wear low but might increase this to 20?)
Operation/Material: RPM, Bit, IPM, DOC - Notes (or step over etc if you want to add)
Drilling/Alum: 1800 RPM, 13/64" drill bit 130deg split-point, 7 IPM plunge rate - drilled 60 holes in one shot, used WD40 with the mister no issues.
Engraving/Alum: 0 RPM, spring loaded diamond drag engraver, 12 IPM - No air/coolant
Engraving/Alum: 1800 RPM, 1/8" 2 flute ball endmill, 3 IPM, .003" DOC - No air/coolant
Contour/Alum: 1800 RPM, 1/4" 4 flute roughing endmill, 6 IPM, .12 DOC - WD40 with coolant mister
Contour/Alum: 1800 RPM, 1/4" 4 flute finishing endmill, 5 IPM, .02 DOC - WD40 with coolant mister
A picture of the dinasour- well because the Internet is boring without pics
CNC: Paul's CNC kit
Software: LinuxCNC
