My understanding is that the lead screw need to turn in the opposite direction to make it happen. Is this correct ?Uh, you start at the chuck end of things and cut to the free end. Normal spindle rotation. That's it.
That's my understanding. My lathe cannot do that. If the spindle rotates counter clockwise ( normal turning direction ), the carriage always moves towards the chuck.You need a way to reverse the lead screw relative to the spindle. Or a LH tap.
You are correct. My HF 9x20 is a knockoff of the Compact 8. There are many websites dedicated to modding the 9x20 and one of them is modding to reverse(called a tumbler) the lead screw. You must be careful because the chuck can unscrew. Here‘s one of the many sites dedicated to modding/improving the 9x20.That's my understanding. My lathe cannot do that. If the spindle rotates counter clockwise ( normal turning direction ), the carriage always moves towards the chuck.
Might be cheaper and much easier in the long run.Sounds like you are going to need a left-hand tap.
I have looked around but unfortunately no such tap can be found ( trapezoidal 15 x 1.5 mm )Sounds like you are going to need a left-hand tap.
