I am making a fixture to rebuild a component inside an automatic transmission. While making the fixture, I had to grind off some hardened steel pins to an exact height. I grabbed a tool that I had made by "accident"for another project an thought someone else may benefit from it.
Take a 3/4 diameter shoulder bolt an cut the head off. This leaves you with a arbor to mount a grinding wheel on. Run the machine at the highest RPM an move x & y. Take light cuts an be sure to cover up the machine to protect from the dust.
I hope this tool will help some one else
Philco
Philco
