My project, a bike light, entails the cutting of two pocket holes into an aluminum block. I'm getting a consistent flaw in the cut, the corners almost always end up being cut deeper than the rest of the pocket. (This may have been discussed previously here, but searching on "pocket hole" and variations isn't getting me useful info)
How do you mill corners so all 4 sides of the slot are even with the corner radius?
I am milling slots in aluminum mold bases to put inserts into for a modification. The inserts need to seat flush on some sides as they will be in part of the wax cavity. My problem is that when I bring my cutter to a corner on the [FONT=inherit !important][FONT=inherit !important]x [/FONT][FONT=inherit !important]axis[/FONT][/FONT] and then change to the y axis cut it leaves an indent. I am using a bridgeport with a DRO and plotting my dimensions from the center of the slot so my cut is x-4/x4. If I bring my cutter to x-4 it still leaves the indent. I even tried a plunge into the corner on the proper coordinates and back milled on the x then continued on my y cut. Tomorrow I am going to strap this beast to a bport with [FONT=inherit !important][FONT=inherit !important]ball [/FONT][FONT=inherit !important]screw[/FONT][/FONT] leads on the x and y and see if there is any difference.
Quoting:
"You might try climbing the finish,or stop .05 away move .05climb in conv.out,you might need to stand next to a practiced mill hand my friend to get it,OR,do like the kids and buy cnc."
Can someone translate this for me?
It seems like you would end up going in and out on the same wall ("climb in conv. out"), then have to do the reverse sequence (conventional in, climb out) for the opposite wall. This would seem to defeat the purpose of climb milling both sides of the corner and preventing the mill from torquing itself into the wall.
What does he mean by, "stop .05 away move .05"? On which axes?
I'm posting for help here, because everyone there seemed to get it and I just don't.
Walt
Quoting:
Walt
