- Dec 18, 2022
- 2,624
So, I have a PM940V-PDF Mill and I am planning on buying the BS-2 Universal Dividing Head which when setup to cut a helix or worm gear will be driven by the tables x-axis lead screw through a geared connection on the left end of the table. Has anyone else here attempted to couple these 2 pieces of equipment? What is the issue you ask? well let me explain.....
My mill is a large bed mill as most who have this machine will know and unlike a knee mill its X-axis power feed is mounted to the left side of the table, the power feed actually hangs off parallel to the table top, over the lead screw en making it inaccessible which is where the dividing head drive gears should mount when it is in use. Well VW, "why not just connect the BS-2 to the right hand side of the table" you ask? Well if I did that it would rotate the opposite direction and the handle and dividing plates would be on the back side of it (away from operator). Okay you say, "Mount the X-axis feed on the right hand side of the table" well.... same issues....
OKAY.... with all of that said here are some of the solutions I see (I am looking for input here) A) I can buy a knee mill x-axis feed which would mount on the right side of the table, this would require custom fabricated brackets which would not be a problem but I am not certain the rest of it would work, anyone else done this? B) I can study making a custom bracket for the current X-axis feed, not certain I see this because the thing hangs on the lip of the table and covers it up. C) remove the feed and operate manually when using the BS-2, I really want the feed.
Anyone think of an option I have missed? Ideas?
My Mill as is currently:
BS-2 Universal Dividing Head:
This is is one connected to a mill (Came from Stock photo, not mine):
