PM932 lube
srfallsallot
Jul 8, 2017
102
Hi all
PM932 with power down feed. My manual states "ISO68 or SEA 80-90 auto gear oil". Charts show that ISO68 is SAE W20 Which is it?
The power down feed has an oiler on the top of the box. What oil goes in there? How much. Does the gear box oil the power down feed? Not the visible gears.
Here's a recent thread:
The first question has been answered before. The second question has not been answered.
The gear box oil does not lubricate the PDF. I just squirt a bit of way oil in there while it's running, occasionally depending on how much I use it. Can use the same oil you put in the head. It's not meant to hold oil for splash lubrication so not very much is needed.
