Flycutters tend to magnify issues with your mills tram. The bigger the flycutters radius, the more pronounced the effect. Is the minor issue your having related to surface finish?
There is flex in the top assembly but I've read that is pretty normal.
You will probably get that degree of movement in most knee mills, mass does help to decrease the flex/dampen vibration, and also centrifugal force of running a balance cutter at higher RPM. Adding either flood coolant or a mist/drip type system can improve surface finish. Old thread on the subject of fly-cutters and balance issues and surface finish issues.
Flycutter Balance Problem / Question
I have a Suburban Fly cutter and their 5" bar . I started getting familiar with it by facing off all my aluminum chill blocks. Roughly 4"x5" one inch thick 6061 blocks . The fly cutter works great but I have to run it in low range in my mill, which is 370 RPM and slow table feed . I can run it...www.hobby-machinist.com
In aluminum I run a 4" face mill with 7 inserts typically at 2800 RPM with an 8-10 IPM and get very smooth finishes, this is just for sizing and the finish improves when I run a air/coolant system. The knee mill is around 2800 lbs. You can run a balanced head at much higher RPM (cuts/inch) but requires the right insert geometry as well as quality of the head to assure they are all cutting at the same height.
That's a sweet cutter!You will probably get that degree of movement in most knee mills, mass does help to decrease the flex/dampen vibration, and also centrifugal force of running a balance cutter at higher RPM. Adding either flood coolant or a mist/drip type system can improve surface finish. Old thread on the subject of fly-cutters and balance issues and surface finish issues.
