PM833TV table "drain" thread size?
LVLAaron
Oct 4, 2020
484
833TV has a threaded hole on the right hand side of the table - Does anyone know what the thread pattern is? I don't currently have a tap/bolt that fits and want to get a plug for it
If that is for coolant drain, it may be a pipe thread. Likely metric which are British and come in two forms, straight or tapered. Most likely tapered.
Agree, probably British standard pipe thread, either tapered or straight
-M
Well that's annoying.
It is the coolant drain... this is all new to me - is there a standard-ish fitting for this type of thing?
I have a coolant system coming... I'm going to guess the fitting pictured here is for the drain in the table...
Do you have a 3D printer? If so, print one up.
You can get BSPP and BSPT fittings from McMaster-Carr, or a local hydraulics dealer might have them too since they are common in hydraulic systems.
