- Oct 4, 2020
- 484
Very much a new guy here so pardon any incorrect terminology.
New 833T in the shop. (with a 1440GT on the way)
I have a Z axis power feed to install, and the instructions might as well be used as earplugs. The instructions say "remove everything" then "install the extension shaft" which is the part in the middle of the below photo.
I'm making some assumptions here. I need to remove the factory geared shaft and install the one that came with the Z axis (photo, left)? The kit also came with a roll pin... I assume that I need to drill that geared shaft so the extension is attached to the geared shaft?
