I'm at my wit's end trying to be able to use a single point boring bar on my PM833T. I bet I don't have 10 hours on the machine if that. The entire head moves around when trying to use a boring bar. I've adjusted the gibs enough to almost cause the bottom screw to fall out without any change in drag on moving the head up and down. It did take some of the movement out of the head but nothing close enough to being correct. I pulled the gib and there aren't any burrs. Tried running the locking screws slightly snug and it doesn't work either. The head is moving on the column as if the dovetail is too loose.
The quill has so much slop it's barely usable to drill let alone try to use a boring bar.
