- Dec 10, 2023
- 85
After watching 55fairlanes saga i also have a PM728VT with less problems, but i would like to make as accurate as possible.
Sounds like this base cabinet needs
1) filled with some concrete.
2) new top surface to bolt too
I can do #1. #2 what do people recommend?
Steel/Alum plate to span the entire bolting area? I don't have a machine bit enough to make it flat or parallel.
Concrete re-enforced with metal? probably to fragile
Epoxy granite that i have seen other people mix together (looks expensive) and pour into a mold. Could embed bolts in it to mount the mill to.
Granite drops from a counter top supplier?
Any other ideas i can set my mill on top of after filling the base with concrete?
Thanks!
Chad
Thanks!
Chad
