- Feb 27, 2014
- 2,274
I am trying to isolate the issue with the G31 Probe code not working.
It could be something with my specific unit or it could be a compatibility issue with the Motion Controller.
If you have a PM45M-CNC can you go to the MDI and enter a G31 X1 F10 (the X and F parameters can be anything that makes sense to you. On my system NOTHING happens. In fact nothing will work (such as a G0 X1) from that moment on until I RESET twice. I don't even think you need a probe for this test to work.
Desired behavior is for the table to move in the X direction. If this happens then I know it is something I am doing. If on the other hand others have the same issue that I do, then I am going to contact Precision Matthews to see of they can work with the Motion Controller company for a Fix.
Thanks for your help.
