- Dec 18, 2019
- 7,319
Fine down feed doesn't seem to work. Could very well be I've misinterpreted the instructions. It kind of looks like its "trying to work". According to the high resolution manual I just downloaded, it says to tighten the knob (4) to clamp (3). I can see the brass sleeve rotating, due to rotating the fine control, but the sleeve does not engage the lever hub until it is very tight. Unfortunately by that time, the whole handle assembly is jammed up too tight to the head. The sleeve then slips.
Can someone enlighten me? I've sent a question to PM, but was hoping someone has seen this before.
