I am in the process of preparing to receive a PM1440GT, expected mid to late October this year 2022. The tracking shows it is currently expected at the Panama Canal on 9/23/22 @ 0200. This is a 3-phase lathe, and I will be using it in my single-phase shop in my home. Therefore, I will be forging ahead with my first VFD installation.
I believe I have read most if not all the posts pertaining to VFD installations on lathes from this group. I am overly impressed with the level of detail and engineering that has been completed in this regard. The quantity of information can get overwhelming as improvements are implemented keeping track of the revisions are not the easiest. I just hope to have the assistance of the most current information of those willing to share. I will be using a Yaskawa GA50UB012ABA for the VFD. I have just received it a few hours ago. As others have stated it’s a big drive! I am looking at an electro-mechanical installation vs digital. I will be replacing the factory contactors for the lathe with relays. It appears that automation direct is a common supplier chosen by many that have done this previously. A few items I plan to order are backordered however the lead time is acceptable with my anticipated lathe arrival.
I am interested if anyone has documented the point to point or schematic for a PM1440GT with a GA50UB012ABA that would be willing to share their work. I have the point-to-point work which has been posted by "mksj" for the Hitachi VFD’s. I anticipate this is very similar to the Yasakawa VFD. His work is truly exceptional.
I would also like to implement the proximity probe option that many have used. What specific proximity probes have been successfully utilized?
I am attempting to locate the specifics for the appropriate breaking resistor for the GA50UB012ABA. I have found a Yaskawa specs for the CDBR braking unit with the LKEB resistor for a 2.2 KW capacity they specify part number LKEB-2 2P2 for the resistor. The spec is a 70-ohm 260-watt resistor. Can the appropriate resistor be installed by itself? The resistor information is in the Yaskawa document TOBPC72060001 on page 14 and 48. I have not completed a good review for info on the braking resistor yet. Any input would be appreciated.
The speed pot per the manual would be a 2K ohm unit. I like the idea of installing the speed potentiometer in a case for the RPM indicator. Any specifics in this regard would also be appreciated.
The previously posted programing for the GA50UB012ABA VFD will be a big help and I may have additional questions and or ask for a PEER check on programing parameters prior to final implementation.
I hope to utilize the stock 3 phase motor if everything works out OK. If the stock motor results in problems I am prepared to source and install an inverter ready 3 HP motor.
I am sure I will have other questions that I can inquire about as I work through this process.
I would like to thank those that have been posting on the VFD installations and anyone else with comments that can help my project move forward without recreating what has already been engineered and implemented.
