Hi all
I have purchased a PM1236 but I won't see it for another month or so. I have had a small lathe for years, one that needed gears changed for any change in lead screw speed and I am/was really looking forward to no more gears when I ordered the lathe. I did realize that switching imperial to metric would involve a couple of gears but that will really be seldom, if ever. I would mostly do imperial. Now that the lathe arrival is nearer, I was perusing the manual a bit and see that gear changes are indeed required. Is it just switching the 24t and 48 tooth? Is that worth complaining about? Again, probably would not be posting if I had access to see the lathe but kind of wondering if this is going to be a pain. Two common sizes for me are 1/4" x 20 and 1/2" x 13. It looks like one set does coarse and the other does fine (ish)? What is the gear swapping procedure like to do? My current lathe required all 4 gears be changed, and each fastening point had to be altered with a different diameter so it was a PITA. Some pitches were accomodated with one gear change but it was usually the one behind others so, yea,....
I am sure the PM1236 will be way better than that! But I was surprised I would be switching anything unless I changed units. Anyone have input for me?
Thanks
Cheers,
Shawn
Thanks
Cheers,
Shawn
