PM-935TS DRO Install
Just for fun
Tim Young
H-M Lifetime Diamond Member
Oct 7, 2020
2,335
Nothing fancy but here is my DRO install. The X access went without a hitch, the Y access I had to redue it and it should really be modified one more time. The Z access has really been a pain but I am getting close.
Setting up the X access.
I machined a little notch in the chip cover, much nicer than using a grinder. LOL
The Y access:
I had removed the X access power feed to gain access to the side of the machine. I had everything for the DRO mounted I was just getting started on the power feed stop when it dawned on me that all the mounting brackets are probably going to interfere with the power feed. Sure enough I was loosing probably 2" or more of travel. These photos are after I rearranged the brackets, loosing maybe 1.25" of travel. It could still be improved but I'm leaving it as is until it becomes a problem.
I made this little bracket to mount the Y access power feed stop switch to.
And since I flipped the switch over I had to reverse the internal switches.
Here is how close the power feed comes to the DRO bracket, the power feed stops a little before that, this is hand cranked until full stop.
The Z access:
At this point I am still trying to get the scales to run true to the machine. I have maybe 3 hours into this and still not quite where I would like it. I did machine a couple of spacers for the install. One for the bottom of the scale and one for the read head that if all goes as planned I should be installing tomorrow.
I know it's not much but this is the one of the first times running a mill so that in it's self was pretty cool, and so much nicer the using a grinder to smooth out the spacer. I cut the spacer out of a piece of aluminum angle.
Looking good so far! Good catch on the mounting bracket interfering with the power feed. Nice to see the way oil dripping down the sides of the Y axis. I probably keep my mill lubed more than it has to be but it's peace of mind. You're going to love learning everything about running a milling machine. A mill has always been my favorite to run in the shop.
I had some time today and finished up the Z access DRO install. I don't really care for looks of the install but it is functional.
I made a couple little clamps and supported the Z access scales in the middle. That solved the issue I was having trying to get it lined up.
Now to get the wires under control.
Oh and one more thing, the spacer I made the extends the mount on the knee. I ended up installing two grub screws so I could get a perfect alignment of the read head to the scale.
That spacer was placed under this bracket.
Is this the MAGXACT MX-200M MAGNETIC 3 AXIS MILL DRO from Precision Matthews?
