Just opened the box on the power feed and spent an hour or two on the install. I find the instructions a bit sparse.
I mounted the unit in place with two C-Clamps and this piece that is bolted to the balance of the PM vertical to horizontal adapter. It's a nice fancy machined aluminum part. After doing this the instructions say I should mark, drill, and tap two holes and then mount the unit. If I transfer punch the two bolt holes where the alignment pieces is connected to the adapter and motor unit, they seem to be in the tight spot.
But this is a bit wacky. Since the alignment piece is threaded (note the bolts visible in pic).....it can't be that I run the bolts thru the adapter and the alignment piece before threading into the table. There would be two threaded pieces in line.So it appears that the alignment piece is a throw-away that is only used for alignment. Seems like the instructions might mention this...but maybe I'm being too picky.
It would be nice if someone could confirm this before I start to drill!
