Weird
That said, as I'm over 60 I find DRO's much easier to read and use vs the dials.
You will love the X axis power feed. On that topic I also removed the ANNOYING safety spring from the other X handwheel opposite the power feed. I get it, the spring keeps it disengaged so you don't accidentally get wrapped up in it but after cussing that thing for the 40th time REMOVED!!Yeah a DRO is on the list after the X-axis power feed.
I had to go out and look at mine. It's in inches. But you can see the gears are metric as it is 0.102" / rev
