I finished installing the X and Z power feeders. They both work very well. The Z axis is a little tricky and the instructions can benefit from a rewrite...
I did not finish the limit switch installation on the Z axis as I realized that as recommended it actually reduces the travel range to 15.5" vs the 17.5" that the mill is capable of and spec'ed at. I might replace the fency stops with the springs (see pictures) with something smaller without a spring that does not consume so much vertical space, not sure why a spring is needed, the limit switches have springs inside and the X axis is not using such stops.
Am I the only one experiencing this or this was observed and corrected by others?
Ariel
Ariel
