Hi
@kmanuele
It is strange that the stiction is in only one direction! It sort of implies that the stiction mechanism is sort of a ratchet or that the system gets bound up in one direction only? Via the PM web page, I see that the PM-728VT has split nuts not ball nuts. I suppose the surfaces of the threads in the spit nuts could have an asymmetry, i.e. forming a bit of a ratcheting effect. But this seems like a long shot.
Does the crank tend to have spring to its motion, but maybe you would not even notice it on this scale? I see this sort of binding when things get a bit tight and this effect is not always symmetric in direction. This binding can occur if the gib is too tight, but you have said you loosened the gib up completely. I suppose that also means that you completely loosened the locks completely! So I am going to guess the following:
When loosening the gib, you must still lock the gib down, i.e. the two end screws are both tight against the gib so that it cannot move. (If not the gib will slide back and forth as you go one direction and then the other. In one direction the gib will get looser will in the other direction it will get tighter and and tend to bind. Since there is no tendency for the table to fall off the machine, you can completely remove the gib and then note the stiction. Gibs are not always well made, so can malfunction. I had one where the tip is broken off causing the locking nut to actually clamp the gib against the corner of the dovetail. This is sort of equivalent to clocking the way. The travel in one direction was cleaner than it was in the opposite direction. This caused more backlash in the one direction. By the way, backlash is not always the same at all points along the travel!!!! (You may not have this problem, but if the ways are not parallel this can happen.)
Other thoughts.
1.) I suggest that you measure the backlash in both directions and see if there is a difference. I am not for sure how to interpret this result, but it would be interesting to see. By the way, what is the backlash. I measure the backlash in the following manner. Dial gauge in the spindle indicating off of a 1,2,3 block that is held in position via a clamping magnetic base. Move the saddle in one direction until you are sure that the motion is accurate and linear. Reverse the motion (crank) and observe the dial gauge to have indicated a moved of a known distance (say 0.005") at this point observe how far you had to crank to achieve this distance. Lets say it reads 0.008", then the backlash would be 0.003" . At this point any further motion of the dial gauge indicator and the crank reading should be linear and equal changes. My machine is a CNC and so I can just tell the table stepper motor to move so many steps, as long as it is several greater than the backlash and get this sort of measurement. More recently I have been using a digital dial gauge which has a resolution of 0.001mm (1micron), or on the inch scale a resolution of 0.00005" (1.25microns). I recently purchased one on Amazon that seems to be decent for this ($64). There are lots varieties advertised, but this one came with a linearity calibration scale over the full inch and I compared it to my PM lathe magnetic DRO. It was pretty close to the calibration provided, but not as good as I would like to see. So the question arises as to whether it or my DRO is off a bit!?). I am pretty sure all of these have pretty good resolution, but I am not so sure about their full scale linearity and accuracy. Google this: "Clockwise Tools DITR-0105 Electronic Digital Dial Indicator Gage Gauge Inch/Metric Conversion 0-1 Inch/25.4 mm 0.00005 Inch/0.001mm Resolution with Back Lug Auto Off Featured Measuring Tool" or
Amazon Digital Gauge Site Link
By the way, they also sell a cable which will dump the dial reading directly into Excel or Word by pushing a button on a small box in the center of the cable. My cable seems to work and can be handy. It is a bit slow to respond to the button (fraction of a second).
2.) (I would only try this after exhausting all other possibilities.) Polish the split nut threads: Remove all lubricant from the split nut and lead screw and run it back and forth for a while. Don't stay on one spot on the lead screw, move around. This is not a good thing to do, but will cause a bit of wear on the split nut, polishing its threads, and to a lesser degree some wear on the lead screw. Does the stiction difference improve?
3.) Is the stiction effect observable at all points along the stage travel distance. That is, is it a function of position along the y-axis?
4.) I assume this is a new machine. If so PM should stand behind it and help you figure this out.
Good luck.
Dave L.
