- Jan 30, 2020
- 10
Hello people
I have a 45M mill that I stripped down to clean out and replace seals and bearings. One thing that struck me is how loose the keyways are. These keys are made as a guide to let the gear slide up and down, not to lock down the gear to shaft so I would expect a looser then normal fit, but this is too loose.
I measured them and came up with an average 4.83 mm on one side and 4.65 mm on the other side which makes me think its a 3/16 key although I would expect it to be metric. I don't think its a 5 mm key ? That would never fit. McMaster Carr only has rounded keyways no longer then 2 inch so I have to buy key stock and cut/grind to fit. Google machinists seem to think (makes sense to me) that it's best to get a key that is a little softer then the gear or shaft, that way if it wears out in the future, the key will bear the brunt of the wear and not the shaft/gear.
So, there are a couple of key material choices as well as different hardness. I don't have a set of Rockwell files to cheack the hardness of the gear and to pay 100$ for a set just to buy 10$ worth of key stock does not make sense for a hobbiest. Basically my easy choices are between 1045 steel d50 hardness or (leaning towards this) 1095 spring steel d90 hardness. Spring steel only comes in standard size, 1045 has an oversized option.
So I am open to suggestions and would like to hear your thoughts, in the meantime I will reach out to PM to se if they have stock or recommendations, but I suspect he is on holidays till next week.
Happy New Years
Happy New Years
