I’m looking to add an X-Axis feed to my PM-30MV. I’ve seen several threads using the PM power feed but not the Vevor. The only difference in specifications that I see in PM uses a 17mm shaft instead of an (apparently) more common 5/8”. Normally I’d just push the EASY button and get the PM but it’s twice the price the Vevor drive which has essentially the same specs,
Has anyone done the PM / Vevor upgrade and if so what were the mods required?
Thanks!
Thanks!
