See posts down below for updated image of chip pan, mounting and other misc dimensions for the PM-1236T lathe.
THANK YOU! That is very much appreciated!For my PM 1236T
Dim 1 = 65 1/16"
Dim 2 = 17 15/16"
Dim 3 = 4 1/4"
Dim 4 = 5 1/2"
Dim 5 = 6 1/4"
Dim 6 = 8"
Dim 7 = 8 7/8" (tail stock width is 7" - depth is same as head stock at 8"
Dim 8 = 16 3/4"
Base Height = 27 1/2" (add 1 3/4 for leveling feet)
Chip panto top of head stock = 20 1/2"
I'll try to tomorrow.@maspann If you can, the next time you are near your lathe, can you measure the following?
Cross slide length and height for mounting DRO scale.
Thanks!Height is 1.3", length is 13.75".
