Trying to keep everything in budget, in addition to what you have indicated I would suggest the following for entry level use.
You will need a number of additional AXA holders for your QCTP. The QMT holders are good enough and very fairly priced (and you do not pay for shipping). I would plan on getting something like ten (total of 12 with the kit) additional 1/2" AXA holders (250-101) and at least two 5/8" AXA holders (250-101-XL). The latter because there are some cases where you may need to run and oversized tool. I would also get MASTER TURNING/BORING TOOL SET (INDXTS-AXA-MASTER), the CCMT/CCGT inserts are one of the most widely used insert, all the tooling in the set takes the same size insert, replacement inserts are readily available at very reasonable prices. I would get better CCMT/CCGT inserts at a later point, a number of us can point you to suggested alternates. This set will get you up and running, with good tooling and not spending 3-4X as much on higher quality tool holder which I do not feel in this setting you will notice any difference in performance. You also get the benefit of the QMT warranty and everything is shipped together at no additional cost. You will want a threading set, INDXTS-THD-1/2, the AG60 16ER external insert and AG60 16IR internal Insert are very common and will allow threading in the 8-48 TPI range. Once again, a great starting point, with out busting the bank. I would ultimately get better inserts for all these tools, the difference in substantial, but learn with what you have.
I would strongly recommend getting an inexpensive DRO (PM 2 Axis Lathe DRO, 6×28 With .0001 Hi Res Cross Scale) basic unit with a slimline 1 micron for the X axis and a 5 micron for the Y. I would install it yourself, you save a lot of money and you learn a lot with the install. You can buy a similar DRO for a bit less through online sellers, or through Asia sellers, but if you have any problems or questions forget it, and doubtful warranty. There are a number of online postings of the DRO install on this lathe.
You most likely will need a 4J independent D1-4 chuck for odd shape work and also those circumstances where you need to be able to get have very low run out on the turning work, so like any type of barrel work. QMT sells the CHUCK4J-8"D1-4 which is a beautiful chuck, but may be more that you want to spend. There are other Chinese 4J chucks of similar size for less, my issue in the past has been that the jaws are often poorly ground, and they are often poorly balanced causing a lot of vibration. Speak to QMT and see what is available if you need to go for something less expensive. My general recommendation is that the stock 3J and a high quality 4J will be all that you should need for the most part. Ultimately consider an ER-40 D1-4 chuck (about $80), to hold smaller round round stock. This is a much less expensive path than a decent 5C setup which will be many times more expensive.
You will want a live center, doesn't need to be anything fancy (the machine only comes with a dead center). I prefer what is known as a CNC or extended point live center, which allows you to work with smaller diameter stock and not have interference with the insert holder, but otherwise just get a standard point. You will need a tail stock chuck, preferably 5/8" (KDCMT3-16), I primarily use a keyless type for almost all my work on the lathe. Nothing super fancy, but you want a decent quality unit.
A starting point, you will need other items, such as indicators, calipers, micrometers, etc.
Mark
