I have what appears to be a dangerous situation when I disengage the power crossfeed and disengage the half nut the cross slide seems to still want to catch and move towards the chuck. I loosed the half nut disengage excessively to test. It is also hard to move the cross slide by the crank, have locking screw super loose. The issue is worse the faster you have the power feed set and it's harder to move in the opposite direction.
What can I start checking as this is highly concerning and I would rather not pull entire cross slide off if I don't have to?
Video of issue:
Video of clearance on nut:
Video of issue:
