- Feb 24, 2015
- 1,382
The next 4 welds are going to be a challenge. I've practiced them plenty and I'm sure I can do the welds, but clamping it up level will be tricky. I don't have a flat and big enough welding table.
When I built my boat trailer, I set it up on saw horses and shimmed and leveled everything.
I'm too old to work on the floor, so I'm going to try something similar on sticking the frame together.
I have a 2' x 3' piece of 1/4" steel, but it isn't perfectly flat and about a foot short, but it won't catch on fire. The plan is to use that, and stand the frame up on machinist's jacks and other shims to level everything. I had a section of 3 x 3 x 3/6 angle that is very square. I cut some 3" pieces out of that to clamp the corners square with C-clamps. That system worked well with the test welds.
