Are you buying the basic lathe or the tooled up version? I'm looking at this same lathe and Grizzlies G4003 and G4003G, what conviced you? I like the varible speed I assume it's a VFD, I don't like the spindle mount and I would like a lower minimum speed. the G4003G with stand is $3550 shipped the PM is $3087 shipped with stand I'm kinda leaning to the G4003G. Did you read the manual about to make your chuck (if not concentric) run concentric that kinda scared me.
I've never owned either and am trying to get the most for my money.
match to PM's off white
FYI, PM's white is not all the same. The older PM45s do not match the newer PM45s or PM932. Rustoleum Satin Heirloom White matches my PM1236 perfectlyl but it does not match my PM45. I believe Mike (ZM) tried using the Heriloom White & it does not match his PM1340GT or PM935.
Thanks, Will. Does Heirloom White look bad with the other PM white? I mean, we are talking about painting the stand, not trying to touch up the lathe. I was also considering using a color they call Putty, which is a tan/gray or taupe. It wouldn't match but would be a pleasing color with off-white and blue.
While I'm at it, Mr. Wizard, how come some of the member photos have a green corner in the upper left?
I suppose that depends on how well your eyes perceive color, some better then others. I can definitely tell the difference from my mill. On my mill I painted the quill bracket with the heriloom white. It doesn't bother me at all but I can definitely see the difference. If you look in zmotorsport's lathe & mill thread you will easily notice the differences. That should give you an idea of how different the whites are.
My PM45 came with a gray stand instead of the "PM blue" as they say like on the new PM45s & PM932s. For very brief moment when I first received it I was sad that it did not match my lathe. But if I ever repaint the stand on my lathe it will be gray. When I repaint the mill someday I will use the heirloom white. I like it better than the stock white but maybe I'm just used to it.
