- Feb 8, 2014
- 11,177
Still trying to get my terminology right So it's one of those two t-nuts. There is a hole on the underside of the block to remove/insert the t-nuts. During usage, when you rotate the compound, once a t-nut ends up in that hole, it doesn't slide back in the t-slot it's supposed to sit in.
cheers,
Cosmin
Make a little longer t-nut, one that has to be tipped to insert it. That way it won't turn in the hole and you can tighten it even in the insertion position. That's what I did with mine when I had the same problem.
