Hi everybody, hope you can help me out on this one.
I've had my 1228 for a little over a year now. I started knowing very little and have been building my skills.
Recently, I tried using the compound to cut a taper. Prior to this, I had literally never moved the compound for anything I did. When I attempted the cut, I immediately noticed that the compound was a lot tighter than the cross slide (which is buttery smooth) and there was a noticeable banding on the cut. This directly correlated to a tightness that happens at one point in the rotation of the handwheel. I'm not sure if I am describing this correctly but, as I turn the wheel, it starts tightening up at about zero on the scale ring, get tightest at 30 and then loosens up to it's loosest around 70. I know those number are arbitrary but that just happens to be where I have the scale ring.
Any ideas what could be causing this and, more importantly, what I can do to fix it?
Thanks!
Thanks!
