PM-1130v - Locking down the spindle, cross-slide, and carriage.
mustangsal
Jan 28, 2021
4
Do these lathes come with locks to keep things tight when machining in one axis or for tightening a collet chuck?
The tailstock has locks for both the body and the quill. I'd love to be able to lock the cross-slide when turning down the diameter of a part...
If they don't have them, would it be bad to add them? If I can add them, where would be the best placement?
Very few lathes come with cross slide locks, the only one that I have seen was on a big heavy Axelson, the only instance that I have observed when a lock would have been of use is on heavy interruped cuts where the cross slid does a lot of movement in and out. Carriage locks are pretty near universal.
As for spindle locks for collet tightening, I have not seen suchlike, on a gearhead lathe one usually just engaged a lower speed gear, on a belt pulley lathe, one usually just engages the back gear without disengaging the bull gear lock pin.
Ooops, wrong lathe.
