- Dec 15, 2022
- 65
Just curious if anybody else has noticed something odd on their 1130V, namely the two hold-down nuts for the compound are some super bizarre size. None of the included wrenches fit them very well. The 14mm does the job but it's very sloppy and would likely round the corners on the nut over time. A 13mm wrench was too small. I took my imperial dial caliper to them and they were both was some odd-ball size like 17/32, IIRC. What I had been doing is I took one of those cheap "stamped" open-end wrenches and filed it to get a decent fit on the nuts.
My customized wrench, stamped from 1/8 sheet metal and it hurts in the hand when tightening, plus the wrench I had was pretty short.
Yesterday I took one of the nuts off and it was just your typical 8x1.25mm. I dug around in the fasteners and found a couple legit 13mm of the same pitch. Life is much better now.
Anyway... anybody else see this?
Hope this helps others that might be scratching their head over it.
