- Mar 2, 2021
- 84
Hello!
I have power feed on the z axis of my new PM-1054-TV, which comes with an adjustable limit switch.
I don’t see anywhere in the manual where they talk about any inherent limits on the knee travel (unlike the head travel where they mention a “point of no return” area beyond which the head will require using straps to lift it while adjusting it back into range).
My question is, is the top stop on the knee travel set artificially low? It seems like I should be able to raise the knee so I don’t have the extend the quill to reach small work when mounted in a vise?
Thoughts? Can I safely adjust the top stop and use the upper range of the knee dovetail travel on my PM-1054TV?
Thanks!
This picture is the knee raised to where it hits the adjustable limit switch stop when set as shipped. Seems like there is more vertical travel to go? Is that the limit of the knee lead screw?
I would love to not have to extend the quill (much) to reach smaller work mounted in the vise:
Thanks!
