PM 1030 Threading Gears question
NavyShooter
Dec 29, 2017
60
Good evening all,
I'm trying to do a bit of threading with my lathe, and need to cut 18TPI.
Alas, the change gears called for in the manual is:
Z2 - 55 T
Z3 - 60 T
Z4 - 50 T
Lower Gear - 60 T
Problem is - I have looked through my kit, and looked at every gear, and I do not have 2x 60T gears.
I only have 1.
Am I supposed to have 2? Or is there another option for 18T that I don't see?
Thanks!
NS
OK, I'll go try that and see what the scratch pass does.
Found another chart that gives 2 more options:
H - 70
50 - 60
75 - H
Or,
H - 65
20 - 45
80 - H
I'll see what might work.
I'm glad I have a SB9, 24 spur, 80 idler and 54 screw.
And....that worked perfectly!
Which train did you use ?
Threading worked great - but I snugged down the steady rest a bit too much - and blew the fuse. Of course I don't have a spare of the right size, so I'm offline until at least Monday. Damn.
