- Apr 2, 2024
- 3
I'm new here, I just want to say hello, and thank you for allowing me to join this wonderful knowledge based forum.
I recently purchased a new PM1030. I'm beginning to think I should have purchased an American piece of heavy iron for my needs. I rebuild transmissions for income, and sometimes need to face the surface of pumps. The most often material worked with is cast aluminum. I do not know the silica content, I would venture to say the manufacturer might not either. I have tried multiple speed throughout the 50-1900 range with a couple of different cutting tips and am ending up with concave cuts of about 5-8 thou across the face. I have indicated the balanced jig setup, and it is running quite true. Tailstock is aligned. The pump has many interrupts towards the outer 9" diameter. Is there an easy way to check parallelly of the dovetail to spindle?
