- Oct 2, 2020
- 88
I'm on a bit of a shopping spree while on big prevailing wage job and just purchased a fully loaded PM-727V mill and now I want a lathe.
Based on specs and features, I'm practically set on the 1022V but while doing some research about building a stand for it, a potential issue arose...
The 1022V has 3 mounting bolts (2 under the HS, 1 under the TS) where as the LMS HiTorque 8.5x20 (a distant second choice) appears to have double that. I don't know the difference in castings, but my question is, for anyone with experience, does this lead the 1022V to suffer in the rigidity department?
The current plan for a mounting stand may make the issue a moot point anyways. On some kind of welded steel lattice frame bench will be a concrete slab (built strong with GFRC/plastisizers) with mounting bolts embedded and some sort of jacking bolts or place for shimming the machine level. Space between the machine and slab will be filled with the same kind of metallic epoxy some have used to tram their mill columns.
If this isn't the best subforum, please move to a more appropriate area.
