- Jul 6, 2022
- 511
I’ve a small amount of play in my cross slide which I tracked down to the hand wheel / cross feed screw assembly:
Hopefully you can see from the above pictures that the there is a gap in one picture and not in the other. This is where the play comes in. There appears to be a grub screw just beneath the red highlight, but this does not move. I’m not sure if it’s seized or stripped or maybe not even a grub screw. I also don’t see how this would help in stopping the play oin the parts. The lathe is a south bend 9 copy so I’m hoping there’s some expertise out there as to either how this adjusts or if I’m missing a circlip from somewhere. Is anyone able to help?
