- Oct 17, 2018
- 966
On my Atlas Craftsman 101.07403 I'm not able to accurately turn a diameter. When I get close to the final measurement, if I rely solely on the DRO I'm usually off by a few thousandths. I've been able to make a deeper or shallower cut by moving the cross feed in or out. I'm thinking this is not good! Well, I noticed the cross feed has about 0.018" of movement and the compound has about 0.012" of movement. I've tightened everything down (I think), so I'm wondering if this is indicative of screw wear.
Is there a way to lock the cross feed and compound in place? Maybe a mod I could do?
As a workaround, when I get close, I take measurements, then move the cutter so it just starts to cut, then look at the DRO and move in the required amount. I was able to turn a steel rod to within 0.001" of spec. However, that was more luck than skill; I stopped short to check and it turned out to be what I needed.
Any advice or solutions?
