I have a very servicable Colchester 13 round head lathe It shows wear but aside from the gear noise is fully operational. I have a MT5 to MT3 spindle adaptor which appears to be in good order. When I test the male MT5 fit to the spindle with Prussian Blue it shows a clean mating. When I test a good male MT3 taper to the MT3 spindle adaptor it also shows a clean mating. However when I test a MT3 male ER32 adaptor to the MT3 spindle adaptor it shows a very poor fit. The blue shows a ring about an inch wide at the big end and little down the taper. This is also confrimed by feel, there is a small amount of movement after firmly setting the ER32 adaptor in the spindle adaptor. (If I over set the ER32 adaptor with a firm taps with a brass hammer I can get a firm fit, not a good practice.)
My question is: What is the best way to repair the adaptor taper?
Can a serviceable fit be created with an hss tool and sanding to polish?
My plan is to use a teper attachment and set it with a DTI based on the good taper. Is this the best way? Is there a primer on this I have missed?
Thanks in advance. Dan
