George- Thanks for the info. The stuff I had been using was Parks muriatic at 20 % (probably similar to the stuff you were using) versus 34% from HD.
Bubby- Thanks for the safety heads up. Yes, I did know of this but it certainly bears repeating. One never knows the experience or knowledge of the audience. Keeping one's fingers, sight and other faculties is paramount in pursuit of one's hobby or profession.
Experimented over the last week. Dunked two castings into muriatic acid at 34%. Much fuming and vigorous activity. To the point where I pulled the castings after 10 minutes. One piece was still bright but the other was darkened quite a bit. I "tested" each casting to see if the surface was different. I used a coarse cut file to cut through the surface looking for a difference in how easy the cut. Didn't detect any real difference. Wire wheeled both castings the clean them up. One was still bright but he other was still darkened.
Diluted the 34% to 20% and dunked the dark casting for 15 minutes. No real physical change in appearance, other than the slight bubbling versus vigorous. Took the coarse file to it an didn't find any difference. If there is a hard oxide skin, it's pretty thin.
Starting to feel I'm chasing my tail...at least with these castings.
My conclusion is that this set of castings from Martin Model doesn't benefit from pickling in the conventional sense. (your experience may vary!) I'm going to machine them without further messing around!!
There may be times when picking is appropriate, it depends on the condition of the castings....
....what is this stinky stuff on bottom of my shoe?? Have I stepped in something...ohhh no!....
Regards All,
SteveK
