- Jan 12, 2019
- 99
Over the week end I bought two lathes in Eustis, FL. One is a South Bend 9x40. This is my second South Bend 9 and I will post that on a separate lathe forum. For this post, the other is a Sears 101.21400, serial 019635. As a person who frequently lurks around on the Craigslist, I see these lathes often (I believe) as the Atlas 618. I have steered clear of them because I simply could not believe that Sears could sell a quality lathe. Upon getting the thing home and beginning the restoration, my reaction is, "Hmm, Not too bad."
The main problem with the lathe is that the connector gear on the banjo is missing and appears to have been missing for quite some time. The feed screw is in excellent condition but was seized in the close feed screw bushing. Tapped it out with the assistance of some Kroil, cleaned it up and it turns freely. I am going to need that gear. I printed the manual from "Vintage Machines" and it is quite helpful. Additionally the small handle on the cross feed is broken. It appears the machine rolled over onto its front. The machine was from an estate and probably did not get the care in handling it deserved.
Now that I have posted this, I will go through the history on the Atlas forum. I will also get some photos posted.
Any thoughts would be helpful.
Tnx,
Doc
Tnx,
Doc
