Sorry for the delay I haven't been online lately I have been moving my shop from where I was setup to my basement . I have a milling attachment on my Atlas 10 inch and it can handle a lot of the things I do, I can also adapt the Atlas milling attachment to the Barker very easily for more options . I have the Barker disassembled right now for a thorough cleaning and to make it easier to move. I have started beefing up the stand that it was mounted on and have a 3 phase motor I am going to put on and set up with a VFD for variable speeds. I plan on using an angle plate and have a nice heavy piece of 3/4 x 7 to attach it to the bed I just have to get some time to countersink some holes in it for mounting . I might make an arbor set up for it for horizontal milling but it has been used is whole life with collet held cutters. The reason I went with the Barker was its very rigid the castings are very beefy for its size, it breaks down pretty easily to move around, its very simple no hard to get parts, and its still in production, and I got a very good deal on it. I am moving everything right now and getting set up at home, No more 3 phase
I cut down a nice heavy industrial work bench to mount the Atlas on and have it just about done, And went thru my old Delta-Rockwell drill press with new spindle bearings and a nice Rohm chuck I got a deal on at a flea market, I also am putting a 3 phase on that with a VFD for variable speed. The other project is an old Craftsman horizontal band saw, I have to make a stand up for that and I should be good to go. T J
