Paying Gig Simple Pins
Doug Gray
H-M Supporter - Commercial Member
Oct 28, 2020
542
This weekend in my humble basement shop I made up a wack of simple pins. These are what I would call structural pins,they get welded to C-channel. The dimensions in the drawing are more "guidelines" or "suggestions", nothing precision required. More an exercise in persistence and efficiency rather than precision.
  • cut to length
  • face one end (so it sits nice for welding)
  • heavy chamfer on other end
  • cross drill
  • chamfer both sides of cross drilled hole
Second photo shows a quick tool I made up for locating the hole when chamfering the second side. The shank in turned to the same diameter as the chamfering tool to allow for quick change out. Thank god for keyless chucks and quick change toolposts.
Not exciting but it got me off the couch and I made some pocket money.
Nice!
I may not be thinking the whole order of operations through, but did you swap in the locating tool after drilling and first chamfering each part?
I wonder if a fixture with a pin or bar standing vertically, clamped to the table so as to hold the hole centered on the spindle axis, and do all 2nd chamfers at once, would be a worthwhile consideration?
They look like weld-on pins for 3pt hitch tractor implements.
Paid work is always nice!
That would certainly speed up the operation.
Another way, how I usually do two sided work on a round bar; chuck it in a 5 collet, spindexer. A collet-block could also work.
A drill bit mounted countersink would be a further speed improvement, but probably not worth purchasing for such a short run.
If the hole isnt crazy accurate what you could do to speed things up is make a drilling attachment to your lathe toolpost and turn it into 4th axis.
edit: still nice easy work for paid work. Wish i could get a few of those.
Thanks for the replies guys. Looking back now, yes a separate setup to do all chamfering makes good sense. This would be speedy and allow for a consistent chamfer depth. There is a possibility I may get quite a few of these.
