- Jan 25, 2015
- 2,558
My setup is an atlas TH42 with an AXA QCTP. Using a parting blade, edge polished on a wet stone to make the cutting point as clean and sharp as possible. I've tried a curved, flat and no back rake angle on the tool. Seems to make no difference other than curling or throwing the chip.
It seems I have to feed into the stock really fast in order to minimize chatter. Spindle speed doesn't seem to make a big difference either, fast or slow. Slow just gets big chatter marks and noise, fast makes finer chatter marks but an intolerable "screech" sound to go with it.
I mostly just work in 6061, but it seems I REALLY have to hog in the parting tool to keep chatter away.
Minimizing tool and work stick out doesn't seem to make a lot of difference. Still chatters unless I feed uncomfortable fast into the material.
I've locked down all my carriages and even gone so far as to lock down the gibs on the compound.
The feed is so heavy that I worry about it digging in. Sometimes it does if the chuck doesn't have a death grip on the piece.
Am I doing something wrong?
I've watched parting videos and they seem to not have to feed as fast I I do to keep away chatter.
I know the atlas isn't the most rigid structure out there, but I've watched videos where guys cut off just fine on a 10/12" atlas and not have any significant chatter. At least not the way mine does.
I'm kind of perplexed. I've gone through most I've what I've found online and I still get chatter....
