Hi Guys
Need some info here, please.
Been trying to part a 50mm BMS round bar and had my 2mm Carbide insert and holder crash boom bang on me ~!@#$%^&*()_
What a disaster
This was quite shocking as the job seemed like progressing quite well. We were feeding merrily merrily and suddenly the earth gave way !!!
We need to know what we did wrong.
We tried our 3mm Carbide insert on another similar-sized project and still could not progress cutting smoothly. The Tool continued vibrating, squealing and still did not cut evenly. Speed here was very slow with coolant flowing nicely. Just gave this project up for the Bandsaw. What a disaster ~!@#$%^&*()_
Lots of obvious questions from this rookie.
Firstly, does the Saddle have to be locked down specially whilst parting ???
Does the Tool have to be exact on centre Axis ???
Won't Setting the Tool below centre line work better ???
Even with nice slow speed and Low Feed why the Chatter, with everything locked down tight ???
With the work drawn even closer to the Chuck, why the heck won't the cut progress smoothly ???
Carbide Inserts were clear on the points - no chips or flaws and still no progress ???
Is it ever possible that a small Tool like the 2mm mounted on a Blade won't cut in a straight line ???
This failure has me fearful of ever tackling such a job again. But then again any project on the Lathe will require Parting at some stage. And we need to overcome our fear first and build confidence to try this again.
Your esteemed inputs will be immensely appreciated and we graciously THANK YOU in anticipation.
LORD BLESS
aRM
What a disaster
LORD BLESS
aRM
