What types of blades are people using for parting on their atlas lathes? The lathe works great for drilling, turning, facing operations, but the second I go to part something the thing chatters and on my aluminum sometimes the blade sticks into the material causing the spindle to stop turning and a belt to slip.
I am using an 1/8" blade at the moment with the tool on center. I have locked down the cross slide, and tightened the compound gibs to lock the compound down.
Basically, I am looking for any suggestions on what to do to fix the problem. The blade getting stuck in the material seems like it should be a clue but i am not sure how to interpret it. Maybe feeding too slow? However, with the chatter problems its hard to feed it in faster.
Thoughts?
Thanks
Brian
Thoughts?
Thanks
Brian
