- Apr 19, 2018
- 65
I hope I can describe this well enough without pictures. I am wanting to hold some aprox 1 inch dia round stock (6061) so that I can cut two flats opposite of each other (180 degrees) and leave a two sided tang centered no more than about 0.200 wide. (about an inch long) I will be reducing the diamater on one end to 0.250 so would have that done before going to the mill(?) to hold from... the whole thing is going to be about 2.5 long. The only thing I have now to hold parts on the mill with is a 4" vise. Ive been thinking of getting some collets (ER32?) and collet blocks to hold that 1/4 inch end and and then hold the collet block in the vise and turning it over once. Or would I hold it vertically and make a cut each side of center? I was also thinking of doing similar with some V-blocks but have more or less rejected that idea for now. I am hoping to find the simplest way of doing this and think I might be overthinking it. While I know I can figure a way to do it, I don't want to spend my budget on tools that may be of little use to be down the line. So I guess my question is two part then; what is the simplest part holding method I might need for this little project and what is wise to buy first as far as part holding tooling for some simple milling. (btw, just surfing today I am going to want to make some version of a carriage stop soon and will need a way to hold some square stock and cut that way V shape?) I am already in the market for a milling vise as the one I have is a little large plus the flats on the bottom under the jaw fall about a half inch short of the fixed jaw making in imposible to hold something small parallel with the table(?) thnx
