Painting micrometers
ARC-170
Jeff L.
H-M Lifetime Diamond Member
Oct 17, 2018
966
I've mics that have chipped paint on the "U"-shaped part. Is it possible to take apart the mic without ruining it and paint the U part and maybe clean the other parts while I'm at it?
I realize the one anvil is bonded to the U, but I could cover that with tape.
I realize they are tools, and these chips are cosmetic (the mics all check out fine), but I do like them to look nice. I also realize the paint may be baked on or something. I'd just like the option of sanding out the previous owner's marks and repainting them.
The only exception is my grandfather engraved his initials on his 0-1" Starrett micrometers that are now mine. I'll keep that.
If at the end of the day if they are still accurate then do what you like.
But post before and after photos....
The U shaped part is called the frame BTW
Touching up the paint is perfectly fine, just don't get any into the rotating parts
-Mark
If you don't want to address a further inquiry asking how to fix your ruined micrometers. go ahead with the proposed work. Micrometers work just fine with careful cleaning and a few drops of oil.
Thanks for the video links. I found those. I've only watched the top one. It was too long; I wish these people would rehearse or get to the point.
How would they be ruined? That's why I posted. If this is not a good idea to take them apart, tell me why.
I don't like carved initials, etc. and am capable of sanding and adding filler to "erase" them, BUT, I won't do it if this will ruin the mics. I'd like to know details as to how they would get trashed.
The second video showed him reassembling it, but he didn't really explain how he got it to point to zero.
-Mark
Thanks! I knew it had a name, but I couldn't think of it.
