Since I have my machine about 70% apart, it the best time to go a head and repaint it.
I'm going to assume using purple power or simple green is ok to use as was/grease remover.
What I don't know is what paint to use. Searching the net, I've found a lot of different paints were used by people such as: oil based, urethane, enamel, epoxy, etc.
I found one thread where a guy used sand blaster (flapping wheel) but I can't see to find it. It made quick work of the original paint. I though about placing the main parts near a heater to help pull the oil out of the casting. Lord know that's the last thing I want in there, oil.
I want do to this once. What primer and paint will hold up to the oil/grease/coolant that these machines commonly see?
Rustoleum battleship grey looks to be close to original color, it only come sin a 2 part epoxy.
Process:
using sanding wheel to take off the the top coat.
Using hot water and purple power to degrease and remove other dirt
Lacquer thinner or mineral spirits for finial cleaning
Prime
Paint
Process:
Prime
Paint
