- Oct 4, 2011
- 727
I finally got my paint cabinet working. This cabinet is built all out of scrap. Took more time to pull the warped dang 2X into something close to square than anything else. LOL The cabinet is 22" deep and 48" wide and 48" tall inside. With the doors open and the top pulled over the working area is almost a 48" cube working area. It uses two 22" X 14" fiber class filters. I just staple them in place for easy replacement. There is 1/2" screen steel mesh under the filters for support. This booth uses a 12" squirrel cage blower. I had to rework the motor to move it out away from the blower (and flammable gasses). The new shaft has a bearing block where it passes through the plywood separator. All of the seams in the air chamber are calked so its as sealed as I can get it. To use it I role it out to the door and pull the 6" dia. hose out down my driveway 15 or 20 feet. This keeps all of the fumes out of the house. The blower is strong enough that you can't smell any paint while painting. Next I want to build a turn table for it on a swing out arm.
