- May 14, 2018
- 335
I am either having a regulator problem or a set up problem. For oxygen, I turn on slowly, open a full turn or two, then set regulator to about 40psi. When I hit the lever to start cutting, it drops to about 20psi? Is that normal? Do I set the regulator with no gas flow and then leave it? Also, during use, the flow slowly creeps up. After a couple of cuts, the regulator had increased to about 100psi. Am I doing something wrong, or does the regulator need a rebuild?
